You’d have to cut t into pieces in the software. A rectangle the size oof the cutting area would work, or you could try to cut in a way that’s not obvious.
If you look at YouTube videos for cutting larger than may size for the Cricut you’ll get the idea.
Technical support can’t help you with your design software questions. I moved this to an appropriate discussion forum, although they will still have to check in now that your post opened a support ticket.
Draw a rectangle the size of your printable area (10.5 x 19 ish). Replicate it (ctrl-J) several times until you have enough rectangles to cover your whole image. (Make sure the snap function is on; it’s the little magnet at the top of your screen. That will make it easy to make sure the rectangles are aligned exactly against each other.)
Replicate your vector image (ctrl-J again) so you have as many copies of it as you have rectangles. Hide all but one, so that you can see what you’re doing.
Hold down the shift key and select the visible vector image plus the first rectangle, and click the “union” boolean function in the top menu bar. This will leave you with only the portion of the vector that fits inside the selected rectangle.
Now make the next copy of the vector image visible, and repeat #3 with the next rectangle, until you have a piece of your vector for each rectangle you created.
Geek2Nurse - Thank you very much. This is how I’ve ended up doing it and its working great. Still learning the vector world so duplicating the image multiple times, didn’t enter my head!
