@dan or glowforge staff, has there been an update for the storage and operating temperature ranges for the glowforge?
As we get close to getting the shipments to the masses done, I want to start looking as to where I am going to store it for regular use.
Even though I have ordered the air filter, I am not sure how it will perform inside the house - like a fryer, that has a filtration system, there is always a smell that permeates the house when we use it, so it might not be great for day to day use (but great if you need to take it to an enclosed space or use it in more comfortable surroundings).
The Garage would be a great place to keep and operate the device, as it would eliminate some of the concerns. In Maryland we don’t get very extreme temperature swings normally, but the Garage would certainly get in the upper 30s, and in the summer probably 90s.
If you don’t have that info yet (couldn’t find it in the FAQ), do you know when you will have it? Thanks
Biggest issue I can see is that before you start the GF up, you will need to get it to human comfortable temperature range.
Very cold to very warm/hot will change the alignment of the beam and moving parts. If it is too cold/hot for your family, then you will want to get the room (and equipment) to that comfortable level for accuracy.
I accept that as a general case, but I would still like to know the specs (if they are known at the time). It is something glowforge will need to publish as part of its manual.
I would say that as the testing labs report their raw data back to Glowforge, then the operating specs can be solidified.
Since the laser tube is sealed and cooling does not require an external chiller unit, upper and lower operating temps would need to be verified (norms, safety and extremes) to the company warranty and liability lawyers satisfaction because we know there are idiots out there looking to score the lawsuit lottery ticket.
I am not an electro-mechanical engineer, but I am a computer networking engineer. I can’t site my source because it was quite a long time ago that I researched it but, as I understand it, a typical range for computer-type electronics (servers, workstations, print devices, etc.) should be ~0ºC through ~70ºC. I’d think you’ll be fine with the conditions you’ve stated. But we’ll see.
Interesting. I don’t think 95F is at all a reasonable high operating temp. It’s often hotter here (New England) and we don’t always have a/c available. In fact, I’ve used all of those in temps higher than 95 before.
We’ve become wussified if we don’t expect our tools to work in temps that are still under 100F (and those folks in the southwest would laugh at even that temp).
Agreed – My car goes well above 113F in the summer and I’ve never had problems with my MBP in the trunk. I bring it in if it’s going to freeze overnight, though.
well, chances are good that it’s not nearly as hot in the trunk as it is in your car barring a hatchback, but even then it’s not like you’re running it in the sunlight at 113. as long as the batteries and stuff can stay cool, it’ll mostly be fine at that temp. i mean the CPU gets much, much hotter as a matter of course.
they’re both LCDs, barring OLED displays; the only difference was the backlighting. CCFLs didn’t work as well in the cold, but that didn’t have anything to do with the cracking.
There can be a big diff between the operating temperature limits of the components and the operating temperature limits of the device, especially on the upper side. To a first approximation, if your chips are running at 65C when the ambient temp is 20C, they’re going to be at 80C when ambient is 35. On the cold side, you only need one tiny place inside the machine to be at condensation point…
