"Straddler" Honeycomb Pins for Crossing Support Bars
Like many of you, I’ve found the honeycomb hold-down pins designed by @eljefe4 to be endlessly helpful. However, there are times when I want a pin right dead-center in the bed, or otherwise in a position where one of the y-axis supports under the honeycomb is in the way. So I utilized aspects of a version created by @DesignsByPhil and made two types of straddling pins: Big Straddler and Lil’ Straddler.
I cut these on medium draftboard, but would love to hear what materials work best for others. For cutting, I tweaked the Proofgrade cut slightly by taking the power from full down to 100 and giving it two passes (183/100/2x). I find this is guaranteed to cut through completely, but less likely to cause charring/brittle points.
For the engravings, I kept the letters in vector format and went with 1000/65/1x for zooms/pews/passes. If you decide to rasterize and use vary power, a similar depth can be achieved on draftboard with color hex code #8c8c8c.
Hope others find these helpful!
Straddlers
Welcome to the forum.
Thanks for these. I will try them out.
Thanks, always looking for more ways to pin.
There goes a bunch more scraps, thanx
Thanks for the welcome! You just made me realize I ought to do something with my profile, so thanks for that as well! Can’t lurk forever. :laughing:
Great :slight_smile: Thank you!
That’s an eloquent entrance. Welcome, and thanks! Good idea.
Simply brilliant.
Fantastic! Thanks!
Very good idea! Thank you for sharing this.
Welcome!! Thanks for sharing your file. I’ll also find these useful for using as guides when I just want to place things in the same spot but don’t want to make a jig. Awesome!
Thank you for this share. I needed this and will use them often.
I have a bucket of hold down pins next to Skippy the Laser. I guess I’ll need to add a bucket of these!
Thanks!!!
Oh, this is a fantastic addition to the laser-it-yourself must have tools! Thank you for sharing your derivative work, it is excellent!
Brilliant idea. These will be useful for sure. Thanks for the share.
As @ellencadwell pointed out, these work very well as guides, perhaps moreso than as hold-downs. That got me thinking about right angles, and so I modified the Straddlers to make the “Always Right”. Hope y’all find it helpful as well!
The Big Straddler is perfect to hold down corners of leather! Thank you, this is exactly what I needed at exactly the right time. :sunglasses:
I feel like “the big straddler is perfect for holding down leather” is one of those sentences you’d really have to explain if someone heard it out of context. :rofl:
I’m so glad that it’s been helpful to you. I’ll remember this, as I’m going to be playing around with some leather next week!
…in the GF, to be clear.
:rofl: :rofl: :rofl:
great way to make an entrance. Thank you for the share (great practical cut!), and welcome to the forum.
