Experimenting with some quarter inch maple veneer MDF. This minimalist stand came out much stronger than I thought it would. Just wood glue holding it all together.
1/4" MDF? Does appear to have an inordinate amount of strength. Now how do you finish this?
The stand is really cool, but I cringe a little at the long-term viability of the pot. (Being a total klutz, I would tap that thing with the vac and it would be a goner.)
We haven’t decided on a finish for it yet. Might stain it dark.
Pretty impressive results.
I have had better luck with paint, since no grain to highlight a stain it just looks like brown paint anyway.
I did a rattle can ‘granite stone’ paint on some mdf and it came out awesome.
Here is a pic - I had tried silver and was not impressed, so tried the granite over it (right side). The silver as a primer worked great (unintended consequences). It actually looked even better after I sprayed a poly seal over the finished project.
tip: Keep shaking the can. Spray spray shake. later rinse repeat.
Impressive. Almost wondering what the breaking point really is.
Put something really heavy in the base to offset that. Kind of like a weeble-wobble (but less breaky).
Something reeeally heavy. Like Mjolnir.
There you go…that’d work!
Very ingenious.
So happy to see this test. Thanks! I always debate buying that stuff when I’m at Michael’s, but I presumed it wouldn’t live up to expectation. Actually looks pretty good, huh!
I have found that the more fingers the stronger it is, and structural shapes can be very strong indeed as long as al; touching faces have glue, A very impressive design showing that off,
Much more impressive than forgetting to hit return for a day
