I recently received the glowforge and compact air filter, and have been using it. It’s awesome! However, the compact air filter doesn’t seem to be working correctly. For instance, while cutting some acrylic, the smell started to be unbearable and had to stop usage. (It’s happened with other proofgrade materials)
Probably know this but worth a check.
In the bed image there is a gear icon on the top row.
Selecting it allows you to let the glowforge know you are using a filter.
If I remember right it increases the fan speed?
Actually, it does the opposite. It disables the exhaust fan. How do I know? I’m glad you asked. It’s like the red tag on the red cord of the automatic garage door that says, “Do Not Pull”.
@mmoyer After you have used the filter for a while, the filter cartridge will start to fill and more power will be required to move the air through the Compact Filter.
I’ve left this thread open. Let us know if you’re still experiencing a strong smell after increasing the fan power.
