I’ve had the orange light of Doom appear last week, thought it was due to the cold in the room, so have been mindful of warming the room up before using it, which has helped. Obviously once warm enough, venting out of the window brings the cold back in. Anyway. It was working ok then today it stopped half way through a print. I turned it off, cleaned everything, heated the room up again and then turned it on. Lots of back and forth later it finally rendered the image. Cut one fine. Then I set it to do two more and the engrave was unreadable and very blurry. The cut didn’t go through. Stopped it, set it up again and finally its cut the rest of the order. However, the engrave is different to before as slightly lighter? So why is this happening and also any other tips to keep the gf warm enough and vent ideas in cold Uk weather!
I’ve added the photo of the correct Baubles and the failed cuts
