Started having a problem yesterday - turned on the GF, and it was stuck on Centering, the head wasn’t moving at all. Checked all cable connections and tried a couple more times.
Same issue this morning, but after failing to center, it says Head not Found.
I have been able to get around this by turning it off and manually moving the head to the center of the tray, but I shouldn’t need to do this and I’m concerned something is going wrong
Hello there,
I’m sorry that you’re having this trouble with your machine. However the problem you’re experiencing may require a bit more in depth of a trouble shooting process, so I’ve created a separate trouble ticket email where we can resolve your machine issue there. That said, I’m going to close this topic and pick up there. Be on the look out for a separate email regarding the matter. Thanks.
