Successful Altoid Tin Engraving
Sharing settings that have worked brilliantly for me engraving designs on black altoid tin blanks from amazon (with gratitude to others who shared their settings, which was an invaluable starting point) :
SPEED = 700
POWER = 80
LINES PER INCH = 1355
CRUMB TRAY = out
tins sitting on top of 0.9" block (in my case, mounted battleship lino i had on hand)
had GF set focus (tried manual entry, but results better with this)
masked tin with blue painter’s tape (important to mask!)
Curious if anyone has suggestion for a protective coating to spare tin from scratching?
Keep forging,
laurin
Thanks for sharing this. Would you care to share a photo of the results?
This is a feature, not a bug. If someone scratches their cool tin, that just makes them a repeat customer :wink:
:laughing:
Your altoids, your time, but your LPI is crazy high… it’ll make your engraves absolutely glacial. How long does one tin take?
I do 900 speed, 80 power and 340 LPI. Works great. A full face tin engrave takes about 6 minutes. I am guessing yours is more like 20 minutes, maybe more? Granted your edges will be slightly cleaner than mine, but at 340 I can’t really see the difference.
After I engrave, I wipe the tin with alcohol, takes up the residue and makes it super shiny. Guessing you know that trick, yours are nice and clean too.
The result is beautiful. I would never consider an lpi this high, however. My eyesight doesn’t discern this level of detail.
Looks great, but as stated, you can bring that lpi way down!!
These look great!Thanks for sharing the settings that work best for you. I know a lot of people appreciate having a starting point.
I feel like spray poly would do the trick for protection.
They turned out very nice. Maybe try Rust-Oleum 2X Ultra Cover Clear spray to protect the surface?
Thanks, everyone! I did lots of testing. Posted the settings that work FOR ME ~ the extra high LPI does take more time, but in the end it polishes up extra shiny, which is what I was after. Glad GF has settings we can all adjust according to our needs / preferences :slight_smile:
@ptodd much obliged! :star_struck:
@ChristyM thank you!! :smiling_face_with_three_hearts:
These look fantastic, and very very shiny :heart_eyes_cat:
Did you happen to try defocusing the laser? aka focusing at a height above the surface of the tin? I do so for engraving acrylic to get a smoother end result, and do 225 LPI. You might try it (up to a quarter inch above the surface) and get the same results at a faster job speed.
very nice indeed.
Mine is as well, but crazy is in the eyes of those doing it. I tried 450 LPI and now I am going back at 1355 full power 2000 speed as I am not looking to make it any deeper. The piece is 1.5 in diameter…
I don’t know why, but that first photo made me laugh!
Hi,
I am try to print on tin and it is not working. Could you please help me and share a little more detail on your settings?
Did you cover tin with painters tape or coat it with anything?
Did you remove crumb tray? If so, did you place anything under the lid?
What material did you mark it as?
Did you hit customize in the settings?
Any help would be appreciated :grimacing: Day 1 for me and it was a flop with the tin and my wood puzzle.
Thanks,
Iris
He was using anodized aluminum tins. When you engrave those, it merely takes off the top coating (see his photo) and exposes the metal underneath. You cannot engrave on just bare tin unless you use a marking medium like Cermark, and even then I’m not sure Cermark works on tin. Anodized aluminum doesn’t need any masking on it. As far as where he placed it on the honeycomb bed, I don’t have that information. If you are using anodized aluminum, you should be able to find lots more information by doing a search…and there’s a lot more information right in this same post.
Can I paint the tin with acrylic paint & get the same results? Thank you
