I would only point you here because it is a replacement machine for you. The procedure clears the logs and is NOT recommended if you have been using the machine and need support to look at the logs.
Turn on your Glowforge.
Open the lid.
Press and hold the Glowforge button. The button will glow teal and eventually blink teal.
The button will eventually turn solid green on its own, and your Glowforge will reboot automatically. Please contact us if the button does not turn solid green.
After your Glowforge reboots, the button should glow solid teal again, and your Glowforge will be in Wi-Fi setup mode. Navigate to app.glowforge.com/setup and follow the on-screen instructions to reconnect your Glowforge to your Wi-Fi network.
Long story short. I need a new modem. On the phone with my Internet provide for 2 hours. They. did everything possible. I’ve got to get a new modem because this new modem that was put in last week has a router and I already have a separate router.
Support. I have done everything humanly possible to connect this new GF to the Internet it is not connecting. Even tried using my phone as a hotspot. I’ve been at this for four hours.
I’m sorry for the trouble when trying to set up your replacement unit. I see that you emailed us about this, and I’ve sent you a response with next steps there, so I’m going to close this thread.
