I had a digital chime that played Aloha Oe and the wired nest doorbell for a long time…
About a year ago the nest doorbell started doing something different, when someone would ring the bell, it wouldn’t chime inside, it wouldn’t ring outside, it wouldn’t transmit the image to the phone, and it would just turn off… pretty useful doorbell.
My initial thought was that the chime was shorting the power to the nest doorbell.
The price of the digital chime was a little steep, so I finally decided to order a simple electromagnet doorbell chime.
https://www.amazon.com/gp/product/B08KYKXY3V
But it’s all about the base, no cover, no problem.
So I went down a rabbit hole of trying to design a kumiko pattern that I liked in illustrator that took a while, designed a box I was happy with that fit the dimensions…
Then I hung up the doorbell…
Some of you out there in internet land probably will guess what happened next.
I rang the doorbell and the Nest doorbell did the same thing, shut off, didn’t ring the bell.
So it must be the nest…
I searched the web to try to figure out why a wired doorbell would have issues…
It turns out the wired doorbell has a battery in it, and when the battery dies, it behaves this way.
So I figured I would follow the guide and replace the battery…
These aren’t designed to open neatly, and after inadvertent bilateral hand phlebotomy the case was open.
Then I sheered the one of the 2 battery plugs off the board.
I thought, will this beast work without a battery?
No luck, it won’t power on.
If I was more confident in my soldering skills in small places I’d give it a shot, but even if I were to get it back together, I kinda killed the front plate ripping it apart and would need to cut one out of veneer, and then build this amazing creation:
to hide the damage to the white case.
So now I am left with this…
Now the question is…
After getting annoyed with Nest, do I go back to them for another doorbell that is destined to fail, or do I go with ring, or someone else.
This nest seemed to be pretty snappy with motion sensing, and had a pretty good camera compared to my prior ring. Ring gave images of people as they walked away from the house, but maybe they are better now…
To close the loop with my initial door chime cover, all isn’t lost, when I get a new bell, hopefully my old chime will work, and I will use this pattern on a new box to cover the old digital Aloha Oe chime.
@bwente how fast could I have made the kumiko design in cuttle? I drew a bunch of lines through an octagon in illustrator, increased the line width, outlined, and merged, but it wasn’t fast.
I finally created a cuttle account, it looks pretty neat, but I haven’t played much beyond the demo.
