I am trying to figure out why the glowforge is creating tiny holes in my otherwise bitmapped coaster file, which these holes do not exist in the SVC. (They look like black dots in the attached picture) Does anyone know why this might occur?
I’ve got a “Stray Point” finder in Illustrator…here’s the file without the points. (It’s going to be a lot quicker than trying to hunt them all down in Inkscape in this case.)
You can find the points in Inkscape by using the Edit Paths tool (F2) and selecting the object. When I selected your outline with that tool it shows the points. Not sure about Illustrator but in Inkscape you have to select each point, or drag a box around multiple points to select, then delete them. It takes time with so many unwanted path points that close to valid points. Keep Ctrl-Z (undo) handy. You will need it.
Not at the computer at the moment but I believe Object > Path > Clean Up > Stray Points, will also catch these in Illustrator. Haven’t compared it to the 3rd party program.
