Trying to figure out 3d engrave and failing hard
In case you haven’t seen this:
It looks like you have the image reversed. the whitest parts of the image should be the shallowest or the surface that is not engraved at all. The darkest needs to be the farther back stuff that gets the deepest.
So for the cube that has the holes in it, that will just not fit with having the closest stuff white.
