I am Craven Edge, and I always hunger
My nephew wanted to do a Halloween costume of a character from a popular D&D show, Critical Role. He and his girlfriend wanted to dress up as Lord and Lady Briarwood, and Lord Briarwood’s sword, Craven Edge, is integral to the story. It’s described as a large two handed sword made of onyx, so I had a bunch of latitude on how to build it. Here’s how it ended up.
I started with the blade, cutting and engraving using the passthrough. This is two layers of 1/8" BB glued together to make a 1/4" blade. I sand an “edge” into it, I don’t truly sharpen it but I think the slight bevel helps sell the whole look. I used a black acrylic ink that had really great coverage (surprisingly black wood stain gave terrible coverage), painted the runes in with gold acrylic ink, then finished with a few layers of gloss polyurethane.
Baltic Birch Plywood blade, spalted Beech, Figured Walnut and Padauk
A closeup of the crossguard and handle assembly. The inlay was done on 1/8" material that was glued onto the 3 1/4" thick layers of the crossguard. it ended up being quite sturdy with an overall thickness of about an inch.
The pommel is 3 layers of 1/4" thick padauk. I cut the parts, then glued it up into a solid blank of about 3/4" thick. I roughly shaped it using a belt sander and then the final steps were all by hand with strips of sandpapers.
It’s pretty and I knew he’s want to display it so I rigged up a wall mount.
More detail on the mount.
A good look at the rose motif and the wall mount design. The rose/thorn motif is the same design of the inlay, a reference to the name Briarwood. True Critical Role spoiler: The shape is a not-so-subtle set of fangs, as Lord Briarwood is secretly a vampire. The fang motif is also present in the blade crossguard.
Baltic Birch, 0.2" clear cast acrylic.
A closeup of the handle, because I mean look at that walnut. So pretty. I spend a fair amount of time sanding the handle to just the right shape. This is the part of the sword you interact with so it should be as smooth and pleasing to hold as possible.
The tip of the blade is actually quite sharp, and since the sword is 49" overall it would be pretty easy to acidentally damage the blade or poke someone. I made a slip-on tip guard that uses friction (with the leather liner) and hinged captive magnets to grab onto the blade.
Baltic Birch Plywood blade, thin leather
And here it is at the costume party:
So yeah, fun project. I’ve made a number of other wooden swords before. If you’re curious, you can find them here:
https://community.glowforge.com/search?q=%40evansd2%20in%3Afirst%20tags%3Aswords
