I have been building some projects and have run into a problem gluing the proof grade plywood. I have been using Tite Bond wood glue and it doesn’t seem to stick well to the finish on the Maple proof grade plywood. I am sure all the plywoods have the same glossy finish. I glued two parts surface to surface, clamped them and after a few hours the parts would still snap apart. Anyone suggest the best glue to use.
Thank you,
Buddy
It can be tough to bond finished woods since you’re gluing the finishes rather than the wood. Somebody else probably has a great answer for you. Personally, I laser-score the woods I want to join so that I’m gluing the woods and not the finish. And by “score” I don’t necessarily mean I use the Score cut type. Although, I’m betting it would work very well. Just haven’t tried it. What I do, instead, is just draw a bunch of random squiggly lines in Illustrator as a bitmap, then size and engrave them into whatever I want to glue. That can give the glue something to hold onto.
That pretty much covers it. The finish on Proofgrade materials is not conducive to adhesive unless removed mechanically first.
For finished surface to finished surface something meant for plastics - unfortunately this means solvent based - something like E6000, epoxy or contact cement depending on the coverage area needed. Even with those, sanding or scuffing the mating surfaces is always recommended.
Thank you for your reply and info. I will try E6000, but will probably change the design to use a different material.
Buddy
I guess I will have to change my choice of material.
Thank you for reply
Thank you, I may try the score method in the glued areas.
Sand the areas to be glued.
I will try sanding, but I think the real solution is to change to some Baltic birch plywood. The proof grade plywood is beautiful but not practical for the projects I am building. Thanks for the input
The question is what is easier finishing the wood or removing some of the finish. By designing many interlocking fingers, any glue is holding the interlock in place with cut-face on cut-face and that is in addition to the main strength of the fingers themselves.
Interlocking fingers is not an option for my planned projects. Mostly toy cars, trucks, and planes. I just figured the proof grade plywood would have a sheet of unfinished hardwood veneer on the outside, My projects will mostly be painted. You learn as you go along. I was afraid to touch anything inside the machine, mirrors, lenses etc. But tomorrow I’m going to do my first thorough cleaning. I love the machine. If does everything I ask it to do. Thanks for all the support I get from the community. One of main reasons I bought a Glowforge.
I can relate to that. I strongly dislike the look of tab/finger corners. Makes projects look hobbled together.
Makes me think in terms of Quions (pronounced like coins)
such as you see of the corners of major buildings.
Quality boxes usually have such hand-carved corners as well.
But not for cars, I would agree, but that makes other problems with compound curves.
“But tomorrow I’m going to do my first thorough cleaning.” Please be careful of a ‘thorough’ cleaning as this is what causes so many people problems afterwards!!
I understand. I will take it easy
Thanks
