With the understanding I am not GF Support, would you be willing to power the GF off, wait 30 seconds, turn it back on and see if it is still broadcasting?
Once the GF has successfully connected to your WiFi network, it should turn off its ad-hoc WiFi network.
When it comes back up, see if your Access Point can see its MAC Address and ping the GF IP address.
I already know the answer to that question too… When I power cycle the unit, it will NOT broadcast it’s wifi. I have to hold down the button until it’s Teal to get it to do that again.
It does however reconnect to my wifi network, get an IP address and become “pingable” again. Just never does it’s homing cycle or come online in the app.
Unfortunately not. I do have a wifi adapter for my laptop that I can put in to promiscuous mode to sniff wifi traffic, but it’s at my office, where my glowforge is not. I’ll probably bring it home this evening so I can sniff it’s traffic
Do you have multiple subnets at home? You mentioned earlier that you have three WiFi access points; are they all issuing addresses on the same typical 192.168.xxx.yyy range?
Interesting. During the setup, the unit is in ad-hoc mode. The configuration happens between the browser and the unit. After this, it connects up to the Glowforge ‘Cloud’.
The only issues during that setup (from personal experience) have been 5Ghz bands (as it only supports 2.4Ghz) WPA2 Enterprise (does not support it) IPv6 address (does not support it- Well it 'crashes and reboots) and a browser crapping out or a plug-in being blocked or just crashing.
Sounds like you’re going to have to wait for support to dive in deeper.
Okay… Everything you’re saying makes perfect sense. Just so you know, I have never seen another user post the screenshot you posted in the OP.
That said… What about another WAP. Say, your phone. If your phone gets a good data signal in your GF room, try creating a hotspot and connect your 'forge to that and see what happens.
I’ve tried that, same result. I just got a VM working and set it up to be an Access Point with a USB wireless card, and connected to the Internet via a wired (my host’s) interface. This way I can man-in-the-middle my glow forge and see what traffic it’s sending. About to head home and give that a shot. If the traffic between the device and Glowforge’s servers are encrypted I won’t be able to see very much, except that there is some sort of communications, and how fast it is to “give up”
Was hoping to get this fixed by the weekend, but the one post from Rita above was all I’ve seen from GF support.
Keep in mind a couple of things that might matter in your environment…
I’m pretty sure the only handles 2.4GHz. (At least it has never seen my 5GHz SSID.)
You only need it to have an internet connection. There’s 0 benefit to it having access to your LAN.
You might want to simplify what you’re said above… Forget the man-in-the-middle and just try a straight shot to your hotspot. But I think you’re saying you already did try that. If so, then I think something’s wrong with the WNIC in the 'forge.
Just suggestions.
I understand you’ve only gotten 1 Staff reply at this point, but I don’t think they’ll have anything additional to offer beyond what the rest of us have suggested. Every test you’re doing will, I’m sure, be evaluated by Staff in order to ultimately resolve your issue.
I honestly suspect there’s something wrong with the registration between my “cloud account” and the I’d love to be able to just delete the Glowforge device in my account on app.glowforge.com and try to re-add it. Doesn’t look like that’s an option though. Okay, headed home to go down the rabbit hole.
I’m not 100% certain, but I don’t think it’s the account. However, Support can delete any and all devices from your account. I think you’ll want to explicitly ask for that here in this thread or shoot them an e-mail to request that they disassociate all machines from your account.
Which reminds me… They had to replace my unit and the old one is till attached to my account. I need to ask them to delete it.
Happens a lot more than you think. (They’re still tweaking a lot of stuff behind the scenes. I got some much nicer sounds out of mine halfway through a project this afternoon.)
