Does the actual print / cut come out with dashed lines?..or do you mean they show up in the UI as dashed line? If it’s the latter, that is actually how the interface looks now. If they are solid lines and you have chose score, they may look like dashed lines but should score when printed.
@jstus I would love to help you out with this, but I’m afraid we’ll need more information to investigate further.
If possible, could you please send me a screenshot of what you see in the Glowforge app when this happens? Make sure to include the rulers in your screenshot and show as much of the bed as possible. Could you also send in a photo of the print once it is completed and, if possible, the file you are using?
To take a screenshot:
Mac: Press Shift-Command-4 and click and drag a box around your image. You’ll find the screenshot file saved on your desktop.
Windows: Click on the Start Menu and type “snipping tool.” Open the Snipping Tool > New, then click and drag a box around your image. Click the Save icon and name and save your file.
