While making some test pieces today I found one vector shape that did not engrave properly. It was a literal Illustrator copy-paste of its neighbor, but one came out fine, and the other was mangled.
Here is what was in the app. All of the text was made the same way, regular Illustrator convert-to-outlines.
And here is how it came out. I was watching it and the laser head was skipping parts of the text on the top left. The text to the right is identical. Nothing else on the job had a problem.
The material was non-PG 1/8" plywood, but I was using a manual copy of the PG HD Engrave settings. (Speed 300, Power 16, LPI 450) But since I was watching the head move it was clear that this issue had nothing to do with the material. The head movement was different for the garbled portion.
multipart kerf test.zip (4.8 KB)
Job was at about 1 PM Seattle time, 12/23/2018.
