Wow! That looks amazing! Great job
Which is why I don’t make “just because” stuff; my house already looks like a neophyte’s hoarder den with all the yard sale stuff we said we could refurb/repurpose.
Amazing work!
Amazon.ca likely carries it but you can find it at auto parts stores too. Also Walmart in the automotive section sometimes.
Truly incredible!!
You might also look for Celastic I ended up with a decent roll of it. Looking just now I see someone mentioned using a heat gun on it but I was using it in a carport with lacquer thinner.
Starting like thin cardboard, it dries incredibly thin and strong and cuts like cardboard in the Glowforge.
Wow. I had never heard of this before. It sounds very similar to worbla, which is a mix of thermoplastic and sawdust essentially. Except it sounds like celastic would be much thinner! I even found a Canadian supplier…$4.10 for a 12x12 sheet. I’ll have to do some experimentation. So have you cut this in your GF? I’m message you for some settings if you don’t mind.
A mix of plastic and light cloth is much more stable so you can stretch it over a surface and not have it fall apart as a pile of sawdust would.
It is basically one-millimeter cardboard as far as cutting it is concerned. and I think that the finished material would mike thinner except it is rarely one layer only. If you nose around an old theater prop shop they might even give you a roll of it as they did for me
This is AMAZING!!!
OUTSTANDING!!! Creating is what we are here for…
That is SO stinkin’ cool!!! You did a FANTASTIC job on it!
