Thanks!! I just used the Q tips and Hot water and I’m gonna let it sit for a few hours. I got a good amount of gunk off and it’ll do for now, then I’ll order the degreaser. I appreciate your write up!
NOT FOR SALE IN CALIFORNIA, All California orders will be canceled.
Not the right one This one is what is recommended by Glowforge but has the same warning. I hope that P&S will change recommendations because of this. On my machine, it dissolved all the gunk and then evaporated, leaving the gunk as a pool of hard plastic jamming the fan and forcing the replacement of my Machine.
I have been using alcohol type hand sanitizer on everything including the little bottle brush I use to clean that fan, It is thicker than regular denatured alcohol and will evaporate better than water alone but leave it for several hours after with the Vivosun pulling air through to make sure there is nothing left.
So I should more look into getting a spray bottle and denatured alcohol or a brush and hand sanitizer? I’m assuming maybe a toothbrush would work fine too.
So far I’ve only done hot water and a qtip and it’s helped a bit but I still have a good amount of gunk left on the fan and the grill.
I just did some random searching for places to purchase 3M™ Novec™ Electronic Degreaser, it looks like the price averages between ~$20 - $25. Whoever is selling it on Amazon is scamming us all.
I would look elsewhere before ordering from Amazon.
I use 90% IPA. Remove fan, power it up stand-alone, spray IPA in to it while it’s running. Yeah, it’s flammable. But the fan is brushless so it’s not an ignition source. Just do it outside and don’t smoke while you’re doing it (Vaping is OK).
