Gotcha. Thanks. I bought this because THEY DIDNT HAVE ANY OTHER WHITE THAT DAY! Grrrr . I have to wander by HD again so I’ll see. If not maybe lowes or even Ace hardware
I can’t tell you how excited I was as I watched it develop. Although I’m sure ever Glowforger does know that feeling. But the crash and burn was not pretty. Just curious if any other color would work…. as long as the chemical make up is the same, it just burns it in, right?
I don’t recall if there was commentary on different colors of paint. you could search norton method. but no telling if it might have been mentioned as a side comment in some other thread.
that’s why I mentioned the actual paint and not the primer. I still think it is more about not enough pigment in the primer. primer is just supposed to be sticky.
The dark one is using the galvanized spray, the white-ish one with the paint . I only gave them one good coat of paint. They are much better, but still not quite happy. The original one that smeared looked a lot better. Would 2 coats be better, allowing a deeper darker engrave?
