What happens if I lose network connectivity during a series of cuts?
qa
#1
As I now understand, there is a portion of the cutter’s workings that will rely on a cloud based service, what happens if I lose network while cutting a design?
Does this differ between the basic and pro models? I would expect that the machine could atomically complete the upload of sensor data and download of cutting plans before beginning a series of cuts to be able to continue while offline. But when using the feed slot, would a network interruption break the ability to sync up cuts across translations of the stock?
#2
The GF has some internal cache and small projects will continue to run if they can fit into cache. Larger projects will pause when they run out of memory and wait for the connection to come back before continuing their work.
Internet access required?
#3
@amos read my mind. That’s exactly correct.
#4
Cool, that’s kind of what I figured. I’m glad that it can recover!
