Camera alignment is spec’d to within 1/4", so you can’t depend on that. As you’ve found, 1mm is typical and works great for layout of designs on material.
That said, the machine will re-print to within 1/1000th", even between power cycles. Focus changes have no effect on laser position, only the image in the UI.
Will you be able to advise what interrupted the process? Both my computer and the GF were left to do their own thing during the entire process. Will the re-calibration be able to resume where it error’d out?
I had this happen several times - it’s generally a WiFi connectivity issue. Even though there’s never been a problem with sending a job or accessing the GFUI, and my wifi shows strong in all meters the calibration requires a solidly strong signal throughout the entire process.
After six failures I connected the GF to my phone’s hotspot and, making sure nothing else was connected to same hotspot, it worked perfectly the first try.
If you are referring to the pink lines being off, that is just the GFUI. The pink lines after the first print are NEVER representative of where they will print on the second and subsequent prints.
Hi Caribis2 - i just wanted to show the result of the camera calibration. It looks like there was an improvement since the initial thread (although this was not the crux of my issue; i was experiencing almost 0.5 in visual discrepancy at times).
I will post on whether there has been an improvement on a multi-step print (which is where i am looking for solutions for alignment between the steps):
i will run the first half of the steps (in this case, my engrave)
confirm it visually looks good, then hit the ‘magic button’ to run the second half, without opening the lid or moving the artwork on the UI
Glad to see you’re getting an improvement, unfortunately 1-2mm is still considered within spec. I get pretty damn close directly center under the camera start position but 2-3mm near the extremities. Are you using set focus?
And out of curiosity, is there a reason you’re running multi-step jobs separately?
If you upload all your steps/operations as one file/job (separate steps by color in your design program) alignment will be dead on between steps and you’ll save some time, too.
We have been using Set Focus (with and without but results are pretty much the same).
I guess thread is evolving a bit with what we’re experiencing as we’re doing tests and calibration. The biggest issue/topic at hand is that we really hope there’s automated registration to eliminate the need for manual (aka visual) alignment.
This camera calibration did help with that cause. Prior to this, we had to give 0.5" space around the artwork cut lines to make sure we don’t end up cutting off the material. Now its a 1-2mm so at least we save a LOT more material already with this improvement.
There wasn’t a specific need for us to run multi-step jobs separately, it actually stemmed from an issue with the camera being super-off, visually, causing us to stop the print between a step. After assessing it was safe to resume, we resumed on step 2, but the alignment between the steps was off. THEORETICALLY, (as Calibis2 is adamant about) the steps should still be exactly aligned because no settings have changed and at this point we were not visually aligning anything, just hitting print button again.
Because of this misalignment between steps, we deduced that there was an underlying issue.
We will conduct some more testing tonight and, crossing-fingers, it will be solved.
We are burning through material faster than it can engrave, hahaha. Again, just really wishing there was automatic registration to eliminate all the human errors.
it definitely takes some experimenting to get the most out of these machines, and there’s almost as many tips and tricks as users! As others mentioned, Snapmarks were the the closest thing to registration marks and they were just a limited beta in service of getting a different feature working. GF never promised them as a core feature so as much as we’d all like them they won’t tell us anything about further development possibilities until they’re good and ready.
If you really need to check critical alignment you can run a score on a very light power setting that’ll only mark the masking to avoid wasting material. This will at least tell you where the laser will fire.
Hit Print. GF did an auto re-focus and it auto-moved the focus crosshair…. Now you’ll see the outlines are misaligned. Fingers-crossed that it doesn’t misalign on actual print since I did not move anything.
Magic button
Print is done; UI output looks misaligned.
Opened the GF lid and the Actual result is ALIGNED!
I put one of the undesirable cut pieces, which birthed this thread, for comparison beside this latest test cut. In the original with the misalignment issue (pre-camera calibration), the engrave task was cancelled after completion (which we reproduced in a similar manner) and was resumed with just the scores and cuts, but the end results were shifted.
On the original (right), you will find that the engraved eyes and nose appear shifted to the right.
On the current test result, everything appeared aligned (or if it was misaligned, it is very minimal)
Conclusion*: THANK YOU for the CAMERA CALIBRATION suggestion.
*disclaimer: still can’t wait for an actual registration solution, powers that may be
It’s not theory. A machine that is functioning correctly will have nearly absolute repeatability (indiscernible to the naked eye).
99% of the jobs that I have ran, the camera wasn’t even used. Set focus, camera calibration, etc. all have nothing to do with the repeatability of a job, or subsequent steps being aligned to the first step.
Thank you, everyone, for all of the awesome help! I am glad your prints are turning out better now. I am going to close this thread. If you have any other questions or if an issue arises please start a new thread or email us at support@glowforge.com.
