When cutting basically any file I have been noticing the cut size changing all over the piece. This happens on all materials and its really frustrating. Does anyone have any ideas? Thanks in advance!
Are you watching the cut? looks like you’re getting the double cut on some lines. Look at your SVG files really zoomed in are there two lines close to each other?
Jules posted this long ago, it might help : Avoiding Double Cut Lines In Your Designs
Looking again I see your circle has the thickness change while cutting it once… this maybe a power issue on your tube then and not a double cut If so the staff here will probably contact you with email and have you cut a test for them.
Thanks for the reply. It does look like a double cut but I am sitting watching it and it just gets bigger and smaller as it goes. Single cut on everything.
