Will only calibrate
i ran a design with 3 names on it. then I changed the names to 3 new names and it has been calibrating for 30 minutes. I cleaned everything before starting the first print which took 26 minutes. I had to shut everything down several times the first time to get it to work which takes too much time. A 26 minutes job ends up taking over an hour to do. Any suggestions
Which model?
Are you starting the machines with materials in the bed already? Try it empty.
How’s your lighting? Make sure you’re not in harsh light, hard shadows can affect it.
“Cleaned everything”, meaning what exactly? Might help to look at this post:
