Am I able to cut or engrave wood after I’ve put a stain on it?
You’ll want to check the stain for being laser safe but yes - check out this post that shows the cool effect you get of raw wood showing where it was lasered
So there has been discussion on laser-safe wood finishes and lasering finished woods. I will leave that discussion to another conversation already in the forums. Suffice it for here that caution is HIGHLY advised.
Just wanted to show you what high speed, low power does on stained wood. All these were done in several passes, for various reasons. You burn away stained wood without darkening the wood underneath.
[22087]
[84765]
[24482]
[471222]
[495698]
Then I put a little oil and wax o…
system
Closed
May 4, 2019, 11:44pm
