Trying to engrave on wooden business cards. Settings are correct for the cards themselves (when I choose wood veneer), however, I am using a 1/8 in. template to put them on as they are printing. The image moves every time before printing, so design doesn’t center where it’s supposed to. Is that because of the 1/8 in. template they are on? If so, how should I change settings to print the cards? Thanks!
Use set focus and make sure the red dot lands on the work piece. Then adjust where you want your graphic.
