“It is called the Baleful Crescent, woe to those who see it unsheathed.”
I continued my sword explorations, this time experimenting with a more decorative grip and unusual blade/guard style.
Quick notes:
Overall length 38" / 71cm. All materials except the guard were 1/8" thick, stacked for proper thickness. Sanded to 600 grit and finished with wipe-on satin polyurethane. Lots of the techniques here were similar to my previous swords, check them out if you’re curious. You can find them here:
The overall proportions are such that someone with medium sized hands can use it either one or two handed. It’s versatile that way.
(Baltic birch plywood, Mahogany, Walnut, Cherry pins)
The guard is engraved with a bit of decoration, but the best part about it is that I made a custom plywood with 1/16" thick layers, mahogany/walnut/mahogany. It gives a really nice little decorative pop on the edge, while the crossed grain alignment is exceptionally strong.
The engraved motif is on both sides of the guard. This is one of the few times that I think using 1/4" hardwoods would have been a better call, at least from the perspective of simplicity when assembling. The scales (handles) are made of a total of 6 layers of hardwood and plywood, it was fiddlier than it needed to be – 1/4" hardwoods would have made that part simpler. I’m still really happy with it, but just something to remember for next time probably.
Quarantine times, I’m not as flush with bananas as I would usually be. But, when life gives you lemons… It’s a surprisingly substantial blade when you pick it up, deceptive. From a distance it looks compact, but then you pick it up and realize you’ll (I’ll) put someone’s (my) eye out if you’re (I’m) not careful.
Final notes…
Other then the 1/4" wood change I am not sure I’d do anything differently here. It all came together really smoothly, I glossed over some of the details about how I managed to make the handle and I skipped the entire “this is a lot of sanding” bit entirely… but yeah, I am pretty pleased.
Special shout out to @shogun for gifting me this excellently dark walnut. He resawed and planed it himself, it’s really nice stuff. He’s an ok guy, I guess. ![]()
