XTool Screen Printer
Hey there! So I just did my first test run using your settings + @shop (1000 / 75 / 270 ) and I just wanted to say thank you guys!!! It was perfect. I attached my screen to the framing and removed the cardboard (don’t toss it just yet). I took out my crumb tray and put in two cork round trivets via IKEA (in the kitchen section in a pack of 3 or 4). I put the cardboard I had removed and placed it at the bottom of the machine then placed the two trivets on both sides THEN I put the screen on top. Same settings with a .125 height.
Have cut Xtool Screens on the glowforge quite a few times now, It is quite easy, 285 sp 45 power is my ideal on the Pro. Works quite well color registration is a breeze, I have forgotten to mirror the file a few times, but was able to stop and save the screens w tape. I am experimenting using a fine screen I bough on eBay and applied my own emulsion. they work well too. but the cost of the Xtool screens $6 per screen is not too bad. have screened napkins, totes, notebooks, koozies, tees and hoodies.
stainless mesh Amazon.com
Speedball Emulsion
Got any pics of your screen prints?
I was looking everywhere for advice, thank you so much for posting. I used 1000/75/270 and it was perfect! Here’s an image for reference.
I removed the crumb tray and used a picture frame (similar size) to raise up the loaded screen up to the proper hight.
My only issue is the GF doesn’t register the full print area which is really frustrating, as a result my image isn’t centered. For the next one I’ll need to make the image smaller if I want to center it.
If it’ll help for the future - this is what the Glowforge sees, and cuts. If yours is significantly different from this, there’s a Camera Calibration that might help :slight_smile:
Has anyone tried on the Aura? Curious if it’s the same 1000/75/270 settings on that or some other settings :slight_smile:
The Aura settings would be quite different as the highest power setting on the Aura is 10.
