Machine seems to be running smooth. Then, as I hit ready and it starts cycling, midway through the cycle, yellow button appears and gives me an error to refresh screen and restart laser.
With everything off check to see if the white cable is fully seated - sometimes if it comes loose it defaults to the yellow button error.
If that’s not it, you’re going to want to set-up the Gift of Good Measure (on your dashboard) and attempt to run it - post the time and images of the GFUI and piece once it’s done and a staff member can look at your logs and hopefully fix the issue!
@corkhats I’m so sorry to hear your Glowforge has a yellow button. I can see that you’ve also reached out via email and I have contacted you there on next steps. To avoid duplicate communication and expedite your process, I’m going to go ahead and close this topic.
