I have refreshed my browser several times, cleared my cash, reset the router and nothing seems to work, unless I just want to print the gift of good measure or something very simple.
Steve
Steve
Firmware updates are automatic for all machines. It checks on every boot if there is one, DLs, installs, and restarts. Nothing for users to do.
Ok then! Iāll ask another question
If I create 1 of the coasters in Inkscape and then make the copies in the GFUI app, will that speed up the preparing your print and get me to the blue light faster?
Here is where a simple phone call would be very useful, donāt you think?
Steve
That one I donāt know as the things Iāve done are one offs. In theory, maybe? But maybe not as it isnāt a clone of the original and you can resize and rotate it independently of the original thereby needing its own path calculation.
3~4 years late to the dead horse party on that one.
Just uploading the design once will save on the upload time, which is why I suggested this.
But not necessarily the time from hitting print to your button lighting up.
If youāve rasterized / made-a-bitmap-of the complicated part, I wouldnāt expect the processing time between hitting print, and your button lighting up, to be very long.
If it is, something else might be going wrong, maybe with your Wifi/cache/etc, that you may need to contact GF to get help with.
I went ahead and made you a version of the file with 1 coaster, that I would try with:
1 Coaster SW.svg.zip (361.6 KB)
Good luck!
Thank you for the help! I tried working on the file last night for over 3 hours and just couldnāt seem to figure it out.
I know I have to learn how to use the software, but you get to the point of just saying the heck with it. I went on a few forums and didnāt get any help either.
When I did a trace bitmap, it came out all blurry, so I tried the simplify idea and just lost too much detail, I just gave up on it.
I appreciate your help.
If I continue to have problems, Iāll contact support again.
Steve
Iām not sure what you mean hereā¦ ātrace bitmapā usually refers to when you already have a bitmap, and you want to turn it into a vector, you can trace it and get vector shapes, that you might use to cut.
But what you needed was the opposite. You already had a vector, but to make uploading and processing easier, you want it to be a bitmap. Thatās where I suggested you use:
Edit > Make Bitmap Copy
in Inkscape.
Learning to use design software can be really challenging. There are good online resources, videos, etc, but it can be hard, and take some time.
Iād recommend lots of the tutorials here:
But specifically lots of thing things linked here:
are great to get some basic knowledge of Inkscape (or the like) for use while lasering.
Lastly @polarbrainfreeze recently started a course on Udemy to specifically teach laser cutting, and the design that goes with it:
So thatās a good option!
Good luck!
Iāll go through those articles! I just made a bitmap copy, but it now looks blurry. Iāll try it again, after I go through the articles you suggested.
Steve
There are settings in Inkscape to how big to make the image that the default is quite low. Before I found it I would scale the image ten times bigger before making the bitmap and then scale it back down after bringing it back in. The result is a bigger raster by far but less āblurryā.
Lately however, I have been doing my raster to vector in Gimp that produces a superior line with nodes where they need to be and not getting confused by the jaggies that the pixels create, and Inkscape gets confused by.
