2: All about masking/protecting your materials
Return to the common questions index
What it is:
On what to look for in masking material and why masking tape is not the same thing as transfer tape:
Where to get it:
Most brands of paper-backed masking material are very similar, so price is the big difference between sellers – in general, getting the least expensive transfer tape will be just fine. Click through for a recommendation for inexpensive masking material.
How to use it:
Here’s a tip for making your masking stick better to your wood materials:
Should I remove it before I cut/engrave?
It depends on a few factors.
If you’re cutting, it’s often best to leave it on because it will protect the surface of your material from damaged and residue.
When engraving, particularly if you’re doing a vary power (aka 3d) engrave of a photograph, the masking can interfere with the engraving details, so it’s often best to remove it before you do the engrave.
What are some other masking techniques or tips?
Masking is more than adhesive paper. It can be liquid, as well. One common technique is to use a thin layer of dish soap to protect the surface of acrylic engraves:
You can also use a more durable liquid, aka a liquid frisket. People have used wood glue to mask material in prep for painting:
Or liquid latex:
Lastly, buyer beware when shopping for paper masking. You can typically buy rolls in 100 foot lengths or 100 yard (300 feet) lengths. In general 100 yard rolls are half the cost per square foot as 100 foot rolls. Don’t be tricked, read carefully!
