This design is for a cubical 3-D maze that you roll a small steel ball through. Drop it in the top twist the cube this way and that, and get it to roll out the bottom.
It is made to cut from a 0.093” thick 11” x 14” sheet of acrylic sold at, e.g., Home Depot. Sheet thickness varies a bit from batch to batch, but this design has worked well with all the batches I’ve used.
Here’s the design as a zipped-up SVG: 3-D Maze 4.zip (32.0 KB)
Thanks for the encouragement.
Give it a try, I think you’ll be surprised how difficult it is to make it through all the twist and turns (and sneaky dead ends). Hint: If turn it and the ball goes farther than you thought it would, it probably went somewhere unhelpful.
@dehne1 Thank you so much for this design. I’ve been so busy lately, I’ve not had much to for laser project. This weekend I had some time, so I thought this one would be great. Once I purchased the correct material from Home Depot it was. The first material I purchase was Lexan (Polycarbonate) as it was right next to the Plexiglas in the display and I was not paying attention.
I’m confused.
I down loaded the file and printed it and it came out great. I printed it the second time and instead of a 3" cube it was reduced to about 2 1/4".
I downloaded the file again and it also came out at 2 1/4"???
Well, you could determine the correct size of the overall design in the UI, then open in Inkscape and scale up to that correct size. It appears to be 336mm wide, but in Inkscape it’s 255mm, so just resize the main design area to 336mm then modify away.
Bummer. I was having problems assembling the original so I thought I would eliminate some of the tabs. Is there any way around this other than opening it in AI?
