the spec sheet is .5 material with tray in however we can not focus on .5 material as the focus limit is .433.
is this a software limit that will be allowable to .5 in the future or is this a hardware limit and the original advertised spec sheet needs to be reneged on ?
Maximum material height with tray: 0.5″ (13mm)
Maximum Cut & Engrave height: 0.5″ (13mm)
Thickness: Varies by material. Can cut some 1/2"
but if we can not set focus to .5 … how are we supposed to use 1/2 ?
