I use Affinity Designer on Mac and have set the workspace custom size to 10 x 10 cm and I bought some glass to engrave that is also 10 x 10 cm. However when I export the AD project (all curves/etc, no bitmaps) to SVG, the image is at least twice the size when uploaded to the GF.
Any ideas?
chris1
June 16, 2019, 1:47pm
#2
See if this helps:
This is the only thing I use AD for, so once I set these up the first time, it automagically loads them every time. I’m sure there’s a better way, but this was my “good enuf” answer…
[22%20PM]
I know common wisdom says set the DPI to 96, but this preserves the resolution of any embedded bitmaps to be engraved.
There is some special treatment of 20in x 12in that should fix DPI issues.
vee
June 21, 2019, 12:14am
#3
Thanks for sharing the link, @chris1 . That should definitely help with scaling concerns on AD designs. @stevekennedyuk , were you able to try this out?
So you’re saying set for 20 x 12 in and that will fix things? We work in mm over here (which would be 50 x 28 cm) I wonder if that works too?
Jules
June 23, 2019, 5:06pm
#5
508 mm x 304.8 mm works. (I also design in metric.)
ivan1
June 24, 2019, 8:54pm
#6
@stevekennedyuk Yes, please give the measurements @jules suggested a try (508mm x 304.8mm) and let us know how it goes.
system
Closed
July 24, 2019, 8:54pm
#7
