You didn’t, but you also agreed to receiving a unit with software in beta, and agreed to accepting it with only certain things working, some partly working, and a whole lot not at all working.
Or did you read those pages wrong?
There is understandable confusion with the images. I don’t know how or why but they are different. When you open a file initially and place it according to the bed image, the laser will burn it right there.
The camera image post op is slightly displaced from the actual engrave, and is easily assumed the laser didn’t engrave where it was supposed to by looking at the post op image.
I learned this on a job where tokens had to be engraved on both sides. After 2-1/2 hours to do the first side, with the sheet of material held in place by magnets, I flipped them all to do the back.
The post op camera image showed a displacement of about 1/4", and I was freaking out that it wasn’t going to register correctly. I knew nothing had moved, so I hit print and it engraved them all perfectly despite the offset image on the screen.
Across 8 months, every file printed right where I had initially placed them, and every post op image showed the displacement from where the actual engrave was.
Well I guess i’m crazy for thinking a 2 year delay would have allowed them to deliver units with less issues and get their software more refined. I get that delays happen, I am a mechanical engineer and have had to delay projects myself, but 2 years… lol.
I am also guessing I missed this announcement stating that alignment doesn’t work yet. All I saw was that agreement box saying that our unit might be scuffed and somethings were being fine tuned still.
I just didn’t know it was that one of the key selling points doesn’t really work. I don’t think this is a ridiculous expectation, but to each their own. We will see what happens over time.
I’m so sorry we missed your message.
The software on your Glowforge is responsible for ensuring that the print lands on the material in the same place as the preview. When you’re done with a print, let a new image load. If the print appears on screen far from where it was supposed to go, you may have an alignment problem.
Most alignment problems come from the material being closer or farther from the camera than expected. While the software is still improving, you can take these steps for the most accurate alignment results:
Should you finish all of these steps, and find that you have an alignment error of more than 1/4", please try the following troubleshooting steps:
Thank you.
