Saw this on the laser forums on FB recently and thought id share. Pretty cool homemade rolling attachment that attaches to the gantry. Looks like the rollers are laser cut acrylic
Neat little piece of innovation, elegant simplicity.
A taller order for us to create sufficent depth.
With my basic, the warranty will turn into a pumpkin soon enough, but before I eviscerate a $2,000 machine there will be a clear path to the goal.
Thanks for the share!
When my warranty is up people like @printolaser will have blazed the way with great mods for 6 months already.
Iāve lived in it long enough to know what my universe will yieldā¦
By the time I reinvent the wheel, Glowforge 2.0 will debue with my manual hacks fully automated.
Iām good with that, it is the journey that I relish. I canāt help it, āBaby I was born this way.ā
Iāve taken apart a few flatbed scanners, some fax/inkjet combo printers and some laser printers. I am saving all the gears and rollers and motors. There is a rotary bed contraption in that box of spare parts!
The one thing with trying to do a rotary assembly in the Glowforge is that youāre going to have to do some adjustment for scale on your artwork OR have something that calculates the rotation rate for the object based on its diameter. Because I doubt the Glowforge software is going to have any compensation coded into it.
I was thinking about rotary attachments earlier today⦠and it seems to me that if you compare engraving a pencil versus engraving a rolling pin, the pencil requires far fewer steps to go fully around than it would take to rotate the wider rolling pin.
So if thereās no plans for Glowforge to add rotary support in ā1.0ā, Iām going to speculate that the easiest thing to do (post-warranty) is to tie into the Y-axis, and make some Arduino-powered roller assembly that connects in place. Something that you could enter the diameter of the object youāre engraving, and have it monitor Y-axis movement to handle the rotation compensation based upon maths.
If you either put the right size wheels, or gear it properly you dont have to worry about Y distance, and it can be a simple machine. You only need to measure the diameter of your object for travel distance.
Having right-sized wheels seems like a bit of an annoying hack, unless you have a LOT of the same object youāre interested in doing⦠I suppose it makes sense if youāre doing larger volume product preparation. I donāt personally see myself using mine for Etsy-like production, but Iām sure others are.
I thought about that, which is why I threw in the āgear it properlyā, because getting the right height for the laser with different objects will be a bit of an issue unless you build small rollers that are geared correctly to provide the proper amount of rotation while still allowing height adjustments. The next question is if you can attach a right angle mirror to the bottom of the laser output block on the glowforge to convert your horizontal space into vertical spaceā¦
Iāve seen a few different ways rotaries deal with oddly shaped cylinders. One used a pair of rollers on either end kept the same diameter, but used a scissor-lift on the narrower side to raise the rollers towards the smaller endpoint of the cylinder. Another went more with a lathe approach, squeezing between a single rotating roller on one side and a cone-shaped roller on the other. Neither required special gearing to maintain synchronous rotation, from what I could tell.
I know this is a year-old thread, but I think this fits best here.
My idea for a rotary device that does not require any mods to the gf. It would not rotate continuously, but in steps. Your design would be split into sections of a width that corresponded to the max adjustable focus depth of the laser, and those would be split into as many layers as needed to get around the material then stacked on top of each other. So if you had a 1"-round shotglass, and the GF can adjust focus within 1/2" you could very well get away with splitting an image in thirds, and having the device rotate the shotglass 120° after each pass. If that distorts too much at the edges, perhaps the image needs to be split into 6 parts, and the shotglass rotates 60° with each press of the controller button. Engrave one layer, rotate the correct number of degrees using a controller that feeds out through the pass-through slot on a pro (or make it battery powered and a wireless controller for the basic), engrave the next layer, rotate, repeat.
I guess, in theory, the GF could broadcast a control signal to a wireless controller that would tell it how to move it continuously, and and do one-step cylindrical objects, but I am looking for a way to make a stand-alone device that requires no mods and no additional work on the part of the GF team.
the stepper motors for the Y position are in the front end of the case. I havent attempted yet, but the belts can probably be pretty easily removed from those motors and belts from a rotary attached to them to allow for the GF to control rotation without it knowing.
The only issue I can see with this method is that before cuts, it goes to the center, right under the camera to do a few checks. If not sure what will happen if it doesnt make it there lol
You could even do this version by hand with a circular/cylindrical jig to hold your object. Score little angle markers on the end circles and line them up with a mark on the holder (using a magnifying glass).
Youād be limited to the 2" Z depth under the head, but that would be OK for some things. Also, for a 2" object, that half-inch focus range gets you 60 degrees from center on each side, which is 1/3 of a circle and might be enough for a lot of applications. Although there would be distortion and power issues as you got away from the perpendicular.
Has anyone with a pre-release tried engraving a small round object with autofocus?
My first thought (some time ago) was in line with this, using an indexed mechanical thumbwheel. By skipping the motor, controller, etc it is obviously cheaper and easier to build, and will take up less room. My concern was that this would require opening the lid between each pass, which would trigger a new homing cycle. So then I started thinking about ways to operate it through the pass-through slot. A drive-shaft from an r/c truck could work, but might be awkward as a rigid/semi-rigid assembly. I had not thought of a drive cable before, but that might work as well.
Ah. Good point. In that case Iād go with the battery-op version, maybe with a stepper, maybe with a servo that could do a ratchet for positive positioning. Easy enough to shield the parts that need not to be damaged.
For control: some kind of photosensor behind a diffusive shield for protection, located at an obvious point on the device. You would include a tiny circular engrave, to be cut 1% greyscale at 1% power (or whatever works) after the main engraving of that layer is finished. So the GF itself would tell the device it was done with the current orientation.
that would be a wonderfully tricky solution.
For a potentially bad solution. Iāve heard rumors that the switches on the front door can be ādefeatedā so that you can run the laser with the front door open (lid still closed). This was made in suggestion for if you had a 2x4 or something similar that you just wanted to engrave something at the top (or bottom) and it was too long for the bed size.
MAYBE you can get it so you can open the front without opening the lid and triggering the homing sequence.
(YES, operating this with the front door open is potentially very stupid. You are pointing the laser at the front of the machine which is now openā¦1. you now need to wear your safety glasses, 2. donāt stand in front of the beam, 3. look for burning holes in the wall opposite your machine.)
As I said, and potentially very bad suggestion
Very, very bad. But the size of things you could rotary-engrave increases exponentially.
That is the kind of thing I am smart enough to know that I am too stupid to do safely.
My idea above does not change the direction of the laser. It would not alter or modify the GF in any way whatsoever. It could be combined with some of the other ideas (like a different laser head that points at an angle for potential larger objects) but does not need to be. That is really the main point of the exercise for me. I do have vague hopes that someone with actual mechanical knowledge takes my half-baked idea and cooks it the rest of the way.
@paulw I know what my luck is like. I have spent much time with Murphy, examining his Law. If I try to bypass the interlocks and work with the door open, there will be an earthquake that will put my face inside the machine.
Iād suggest not trying to engrave hard drive platters with the door open. They are apparently very effective CO2 laser mirrors.
