I’ve got a 550 CBM booster fan coming today to try to mitigate how much smoke leaks when I’m doing cuts, but seems unusual that I need to do that.
I cut proofgrade basswood the large majority of the time. I’ve cleaned both the exhaust fan and air assist fans many times and it never improves the smoke issue.
I didn’t have smoke issues for the first week or two after I received my Glowforge, but it’s been an issue for quite a few months now.
when you have smoke issues, it’s almost always some sort of obstruction issue in the exhaust tract. for me, i once had one of those dryer vent flap covers on the outside of my vent solution. it had a screen inside of it. that screen filled up with residue and gunked up and blocked airflow. it could be anything from inside the machine to the point that the air evacuates to the outside.
First thing to look at is the grate in the forge at the connection point.
Second thing I would do is look at moving the forge closer to the vent, as it seems like you have a bit of room to do so. The fewer bends in the hose the better, and the less length the better.
Third, I would double check the window. In the picture, there seems to be a bit of light (but could be flash reflection) on the left side of the window. If it’s a gap, that could be a challenge.
You may also want to tape around the hose connection to the vent.
I woudl also consider looking at a different hose. I;ve use a thick plastic dust collection hose from Powertec (Amazon Link) that help the smell for me.
If you start to see smoke filling up inside the Glowforge or seeping out into the room around the lid while a print is running there are a couple of things to check. Taping up the seams on the machine to keep smoke from leaking out is not a good option.
Air is supposed to flow into the Glowforge through the cracks in the lid and from the air intake underneath the right side.
If the machine is filling up with smoke it can be caused by several issues.
One of the most common fixes is to remove the hose at the back of the machine and check that the grate on the back of the Glowforge is not clogged. It can be cleaned with a pipe cleaner and a vacuum if needed.
The exhaust fan at the left rear of the Glowforge is what pushes the smoke out…make sure it is spinning up and running strong.
Check that you have not accidentally set the machine to Compact Filter Mode in the Settings panel n the Glowforge Interface. That reduces fan speed and the air won’t get pushed out. (If you are using a Compact Filter and the machine starts to fill up with smoke - it’s time for a new filter.)
Make sure that there are no loops or tight bends in the exhaust hose. You want the shortest length possible to get it to the window, so if you have something that droops, cut the hose or tape the accordion folds closed to shorten it. No more than two 90 degree bends is optimal.
Check the outlet port as well, from outside. It might have been blocked by something, or there might be junk built up in the hose.
If you are getting excessive smell from small smoke leaks that are not originating in the machine, check the entire length of the exhaust hose and port to make sure it is air-tight. Taping up the connectors and any pinholes with aluminum tape can seal the path for the smoke to exit.
You have three right-angle bends there, and the first (at the machine) is severe. That’s the primary source of your issue - only two bends are recommended.
Your external fan will take care of it. No, don’t have to tape my machine.
There’s a normal amount of smoke in the machine it looks like, and it appears to be evacuating towards the exhaust port so that’s good.
I’ll tell you what might help more than anything else is shifting that table over so that you can get a straighter (direct) run with the hose to the window. Or moving the glowforge over to the other side of the window. Is that possible?
By design the exhaust fan moves more CFM than the intake fans, so the machine should be sucking air in all the cracks.
A couple of months after I got the laser I started getting smoke like that and like you, my first solution was to tape the cracks. It continued to get worse until the room had a cloud of smoke in it. That’s when I realized that it was an accruing issue.
I discovered the exhaust fan grill was almost completely blocked by smoke particulate, essentially a very fine ash.
Whatever the cause, the machine is not breathing as designed, so taping it is treating the symptom not the cause.
Just moved it directly in front of the window and used a short piece of vent hose so it’s basically a direct shot out…still billows smoke out of the machine.
Sounds like I need to dig in to the fans a bit more to see if something is up.
Did you check the grid behind the exhaust fan? If it gets clogged up it can inhibit air flow too…vacuuming it and brushing it out on a regular basis is a good idea. (Oops sorry…i see @PrintToLaser just mentioned it. Can’t see that on a shortened screen.)
I probably don’t do as much wood as other people, but I shoot compressed air back there quite often to keep the fan itself from getting build up. With such resinous, sticky stuff, once it starts, it just grabs more and more, I think.
I think your problem with the fan junk building up so quick is that extremely sharp bend right at that flange. The exhaust is hitting that immediately and probably causing some weird circulation. Think about how a river flows around bends and you have fast water, slow water, etc.
You might even be creating an eddy right there at the grate.
On top of that, it’s not like it’s mandrel bent pipe; it’s soft, flexible tubing that is compressing down to less than its 4” diameter, so it might not even be able to shoot the full 200cfm through it.
