So if you go to http://www.homedepot.com, and type “glowforge” you get 5 plywood products (all 1/4") from Columbia Forest Products. Anybody tried them? Are they actually good to laser?
I haven’t, but: " * Contains 100% natural wood bonded with a food-grade soy-based adhesive that does not emit toxic air contaminants. Decorative top veneer, measuring approximately 1/42 in. thick, exhibits the beauty and timeless quality of natural hardwood and is suitable for painting or staining" sounds pretty good
Probably not finished like
Not yet, but I did reach out to them about getting some 1/8’’ .
Thank you for your inquiry. I am working on putting a 5/32" veneer core panel online. I should have it ready to go in a couple of weeks. I’ll be doing it initially in maple. If that panel works well for the GF community, I will offer it in other species as well.
That was two weeks ago. I would expect to see something early 2020.
Haven’t tried them yet. But Rugby ABP carries the same stuff and they’ve been providing stuff for lasers for years as the architectural market does use a fair amount for models so I’d expect they’re fine. If you have a Rugby nearby you could probably check it out in person vs having to order it from HD sight unseen.
I have used a lot of their “Revolution” plywood that is both least expensive and decent quality. The top and bottom surface of the Revolution is extraordinarily thin but that is as bad a thing I could say about it.
Wait rugby carries that stuff? You know what they call it? I’m miike three miles from one, that’s where I get by B/B grade Baltic birch ply (not B/BB)
I have tried the columbia stuff from Home Depot, using it now. Beautifully finished, good flat wood. The only issues I’ve run into is you can’t use the flashlight test, as it’s too thick. At least I haven’t had any luck with it. And I’ve run across several hidden hollow spots, and there’s quite a few knots, but I have been able to work around them. Overall, I wish I had ordered more. I’m almost out…
The point to this is they are in pre-cut packs of 10 sheets, at a very reasonable price.
If you go to the GUG (glowforge user group) on FB, they actually will respond to questions in the group.
I suppose that wasn’t the biggest mental leap. I’m wicked smart you see.
As Shop mentioned, the group on Facebook actually has a ton of users of the stuff.
I have used quite a lot of the 1/4 maple. I have found it all to be very consistent, good quality.
Seems the consensus is that it’s good stuff. Gonna have to pick me up some.
Aw sad. I’m gonna be in Vegas in January but looks like Rugby’s Vegas store doesn’t carry it
Two locations in “Atlanta”, both about an hour away. Perhaps if I have reason to take a road trip… I’ll take snacks.
try a halogen shop light.
That looks very (and intentionally) bendy, more so than BB. But it’s cool they have 1/8! I have a pack of 1/4 maple I haven’t tried yet, but it looks beautiful.
Yes! I just got a load of maple in and it burns really well. Their customer service is awesome too!
