Just about to “upgrade” to the pro from my aura. My aura’s filter was useless. Several discussions on facebook made me decide to vent out window. Now my aura works much better. Does anyone have the pro and use the filter they sell vs. venting out window. Trying to decide if I get filter. Don’t want to get stuck with filter like I did with the aura one. Thank you.
If you have the option to vent out the window, you definitely want to vent out the window!
Laser filters are great if you are in an enclosed space, but they are expensive just because they do grab everything and therefore need to be replaced frequently. That is equally true for the Aura filter, the Pro filter, and literally every other laser filter out there.
That’s what I was thinking. Thank you very much. It’s just I live in Arizona, so summertime is going to be a bit rough venting through window. lol
You should be able to vent out the window without issue no matter where you live. The air is moving from inside to out, not outside to in.
Welcome to the forum @twins . Search for venting in the forum and you will find many set ups that allow venting in very hot and very cold climates. As @dklgood said, the air from the Glowforge is moving from inside to outside. It will be a good project for your Pro to create an airlock for the rest of the window or many have used a purchased dryer vent with small modifications. Venting out the window is definitely the way to go if you have the option.
Get yourself an inline fan, and a blast gate, and you’ll be good to go!
I leave my window up, and made an acrylic inset that, surrounded by insulation tubing, keeps all the midwest heat and humidity outside. It should do just fine in Arizona!
Here in jersey it’s equally freezing in the winter and highly humid and hot in the summer. In-line fan, hose through multilayer styrofoam I glued up that fills the window gap whenever I need to use the laser.
I lived in Tucson for years and in Tampa now, and had to add a new roof when I moved in. The basic stuff is about 4" of foam with aluminum on both sides and of course, there is no roof that will use an exact amount. If you check around with roofers you might get a bit of their scrap.
So I took a six-inch wide piece the height of the sliding window and cut a four-inch hole in it. after that, I taped the outside with aluminum tape and purchased a standard four-inch one-way exhaust vent tied to an inline fan that is tied to the Glowforge.
The Vivo fan I purchased is too small (200cfm) to do the job alone so if cutting something smokey it does not keep up. However, I let it run 24/7 (as it is designed to do) and then run the regular exhaust when the Glowforge pro is running. As a result, the interior of the machine builds up gunk a lot less than otherwise.
