I did do a forum search but strangely found no relevant hits. Does anyone have a recommendation for the best glue to use on Draftboard? It’s kind of porous so thin CA glues can soak in pretty fast and become ineffective.
My application is a bunch of really thin Draftboard cutouts that I want to glue on a second piece of Draftboard. They are being held in place right now in the cutout waste piece, on top of a piece of masking tape. So I want to apply the glue to all these thin bits then place the backer board on top, without it sticking to the cutout waste.
I’ve been using the slower setting LocTite GO2. It’s got enough gel to it that I can move parts enough to align. It sets up well and holds, but I always use clamps.
I’ve done the regular wood glue to as @jbpa notes and it works just fine.
I’ve been using CA glue. I have enough time to put it down, positions the part and wipe off excess before it sets (usually).
I think wood glue would also work (and probably give you a stronger bond). I haven’t tried it yet with Draftboard.
Thanks for the help everybody! I ended up gluing it with Gorilla brand wood glue (the yellow stuff). It’s drying now. I’ll eventually show you the project when it’s done.
It works really well. If the surfaces are pretty clean it will set almost too fast. When I have been too lazy clean, it will even glue charred wood pretty well.
So far I’ve just used plain old white glue for decorative stuff. It works fine for anything that’s not going to have much force applied. I’d probably use a good wood glue for anything structural.
Does their wood glue expand in the presence of moisture? The original formula foams up in contact with water – blessing or bane, depending on the use case.
