I am trying to engrave on black acrylic and then apply paint as I have seen before but my engraving lines are bumpy. Is there a special setting
I should use to get a smoother look so the paint looks crisp?
The trick you’re looking for isn’t exactly a setting, it’s a focus thing.[1]
The concept is called “defocusing”, you basically intentionally set the wrong material height on your engrave. Bunch of threads here:
https://community.glowforge.com/search?q=defocus%20acrylic
Great examples here from @takitus:
Which I guess is technically a setting, but you get what I’m saying
Very helpful I am giving it a shot now. Does this mean after I adjust the settings to .2 and 170 LPI that i should not hit auto focus ?
So you hit autofocus first, that sets the camera view in your UI for layout and visual alignment.
Then go into the settings for your engrave on the left and set the height manually. (see the bottom bit)
I generally use very high LPI, especially with acrylic in order to get rid of all the bumps. Defocusing helps, but the waves remain. At 1355 LPI the waves are smaller than the detail.
Thank you so much I cant believe how much it cut down on the engraving time ! How exciting. Thank you so much ![]()
Not sure what happened I used clear acrylic 1/8 . So I tried the .20 and LPI at 170 but it almost looks like it barely engraved ![]()
NVM I am an idiot . somehow full power was not on lol
If that’s not a typo… 170 LPI is pretty low. I don’t know that I have the patience that @rbtdanforth does to go over 1000, but I’d probably invest the time to go at least 270, preferably 340. You do get noticeably smoother edges that way.
Oh shoot I thought your video had 170 lol Thank you I will try again
worked. Slowed the engrave time down but the outcome was smoother Thanks again
The change in focus by itself shouldn’t impact the engrave time. Only layout, speed, number of passes, and lpi have any impact on job duration.
