@CMadok so I guess its probably not safe to cut then? I asked in the store and they were not able to give me any info at all.
While I was there I happened to also see this but it looks like MDF coated in laminate.
The reason for these questions is that it is almost impossible to get Laser stuff here in Switzerland. They have a ton in Germany or Austria but Switzerland has an import limit of $65 (franks… about the same). Anything over that we need to pay 7.7% tax plus a fee for how much it weighs… its ridiculous. Trotec have material but their shipping cost is $39 and their sizes are 600x300, which I guess with the passthrough slot on my pro I could shorten but its still annoying - and expensive.
The hardware stores have a lot of poplar wood (that hobby wood stuff) but that burns really easily and for name signs; which I make; the wood just soaks up the paint, even with a proper sealer. Then there is plywood but its made up of quite a few layers and for some reason the glue is terrible, every time I cut it the edges are burt black and the stuff goes all over my fingers, basically like you are taking wood out of a fireplace.
So at the moment, a simply name sign takes me about 4-5 goes (2-3 hours) to get the settings right because every piece of wood is different and I need to test the settings multiple times. One day I got so fed up, I wrote to my Etsy customer and asked if it was ok to just print on Cherry wood and I used my last piece of Proofgrade I got with the machine. Took less than 10 mins, printed perfectly with 0 burn.
Here is an example of some plywood I got off Amazon, Simply 2.3mm sheets A4 size, so way to small. Same thing again, quality is just not there and cost is too high.
So hence my constant quest to find something that works. Our stores, Hornbach, Jumbo, Do-it Hobby and Obi all have terrible stuff.
This is Hornbach plywood
You can see from the Jumbo plywood how many layers of glue it has.
Sorry about the complaints but its getting so bad I am considering selling the machine.
@MakerMatthew I am in Zug. I have tried the migros stuff, its just very hit and miss.
