Congratulations on finally breaking it out of the box! ![]()
You’re going to have much better luck using the Trace function to capture an image of your artwork and turning it into an engrave on wood that you can then cut out around. Without the Snapmarks, (which haven’t been released yet), there is no fiducial marker on your drawing that can be used to line up the cuts accurately around something that is drawn by hand or pre-printed on an inkjet printer.
If you do want to do a “Print and Cut” style file now, you’ll need to use the method outlined by @cynd11 here:
(*Unless your machine had Snapmarks assigned to it during the Beta test and you were never aware of it, in which case you can read about how to work with them here.)
