Here is the data sheet it says it is PVC with silicone coated paper backing.
orajet-3258-id10780-technical-data-sheet-americas-en.pdf (orafol.com)
Nope. Never anything with PVC.
darn, ok thanks so much!
Try these, they’re polyester and cut really well:
Thanks for the answer @Jules, that’s right! While you can use many types of plastics in your Glowforge, unfortunately, vinyl isn’t laser-compatible. When cut or engraved, vinyl can release gases that are hazardous to people and can cause damage to your Glowforge.
