Can't cut a tracing. Won't let me change from engrave
Welcome to the forum!
This behavior is correct, so you’ll need to add your own cutline around the artwork using a vector editor such as Illustrator or Inkscape.
You might find the first link in “the Matrix” helpful…
The best place to start is “Designing for the Laser”
EDIT: If you’re working with the GF scan/trace function, it might be helpful to review the tutorial, especially steps 7-9.
