Can't print - fails on preparing design
Are you trying to cut 0.5" material on top of the tray? The maximum focal thickness of the material that you can cut on top of the tray is 0.433 inches.
If you want to cut thicker material, it helps to remove the tray and prop the material up into a half inch range that falls into the correct place, using this tutorial.
Hope that helps.
