Towns, settlements, and roads – designed for PG medium acrylic. The buildings are 3 layers each, with the chimney layer in the middle.
(Right click the image and choose “save as,” or just click here,)
Numbers and “robber” - designed for PG medium plywood. Make sure the diameter is correct to fit your hexes (I imported / exported mine several times and am not sure the sizes ended up the same as they started out!). “Ignore” the alphabet layer and cut/engrave the number layer, then flip the pieces over to engrave the letters on the backs. For the “robber,” cut two of the “7” piece, sandwich the plain piece between them, and use the small circle with the slot in it as the base.
(Right click and choose “save as,” or just click here.)
The VP disks file didn’t want to show up for some reason, so here it is zipped: Catan VP Disks.svg.zip (277.0 KB)
It’s an amazing community to be a part of. I am so appreciative of the positive, helpful attitudes of almost everyone I’ve encountered here. It makes me WANT to give back!
Yes! The atmosphere here creates a feedback loop. It’s the people, and the creative tendencies we are collectively afflicted with.
I really am an introvert, but you wouldn’t guess that from my behavior here. A welcoming place where I have no problem crawling out of my shell, uncharacteristic of me.
