Hi Folks,
before I go to support with this issue I would like to ask everyone here if this is a problem or not.
I have not used the GF with the tray removed recently so I want to check if I’m doing something wrong. I want to engrave something on the lid of a wooden box. The box is just over an inch think (26.8mm) so I need to do this with the tray removed. However, when I put the lid in the GF and go to do the engrave, the lid appears much smaller than it should.
The square should be the same size as the lid. When I repeat this engrave on some scrap plywood with the tray in everything appears as it should. Is this normal? I’m indicating the correct thickness of material so the focus should be correct.
