Hello,
Is there anyway to stop the conversion of dashed lines when uploading an image?
They are only dashed when not assigned a job. Ignored or not yet assigned they will be dashed so you can tell they are not assigned.
This conversion is being done during the upload process. you are referencing the image after uploaded.
Yes that is where it starts. Give it a setting and use Set Focus and it should be a regular line of a different color
I’m guessing you’re talking about using a brush to make a line look dashed in your program, but when you upload it to the GFUI it removes all masks so it shows a solid line instead.
If yes, yes - but it depends on which program you’re using. If it’s Inkscape there are instructions here:
and Illustrator (which I don’t use so I can’t vouch for this method):
