Well, my wife is now 100% on-board with the Glowforge. She was putting these weird little plastic boxes in one of the drawers today, I told her I could cut a custom fit tray, and three sheets of Medium Draftboard later, here we are…
I used the Inkscape tabbed box maker, set to inches. Box dimensions to match the drawer, tab width of .5", line thickness Hairline (0.002" for Epilog), material thickness 0.13, with kerf set to 0.007. Joint clearance 0, 3 dividers in each direction, keyed into all sides. .007" was just right for the medium draftboard, I tapped everything together with a rubber mallet and didn’t need any glue. Deleted the holes I didn’t need, and edited the dividers to fit based on the changes I was making.
I tested everything out in Amazon Box first. There really should be a material preset for that…Cut at 180 speed/60 power.
so, my recommendations…do some “stub tests” with edges of generated boxes to dial in the kerf for your material, if you’re trying to avoid gluing…then prototype the whole thing out in cardboard. I realized there was a lot less that I actually needed to cut, and it helps you figure out the assembly order.
I have a -style “Amazon Box” type defined in my Glowforge Material Manager. It’s just literally cardboard used for general Amazon boxes. Great source of free material, I get a few every couple of days.
@jbpa I started out planning to make it movable, but then I realized it was near golden-ratio parameters, so I just cleared the extra holes and set permanent dividers. The clean layout is better for my OCD.
…but out of the whole thing, I missed about a third of a partial hole in the foundation.
don’t use boxes with oil/grease stains, and don’t burn unattended, since cardboard can flare up…but I cut this without masking, and as you can probably tell, there was not much charring/burning at those settings.
You might want to add a thick coat of varnish to that Draftboard as it is not at all happy in te presence of soap or water, and would even stand up to abrasion better too/
